Wisconsin Engine troubles
Kurt
04-13-2003 19:47:33
I recently purchased a Ditch Witch Trencher with a Wisconsin VH4D Engine on it. The engine runs fine when not under a load, but when I start trenching with it after about 5-10 minutes the engine seems to bog down until it stops. If I let it set for 10-15 minutes, it will start again and do the same thing. I already repaired a leak around the carberator, which I though might be causing it to overheat. If anyone has suggestions I appreciate it. Thanks!!
rob
04-19-2003 08:54:07
 Re: Wisconsin Engine troubles in reply to Kurt, 04-13-2003 19:47:33
The wisconsin is notorious for this , check point gap and condition as worn points change timing and causes engine to work extra hard. You could also have carb out of adjustment, float , mixture etc... There could also be a mouse nest behind the engine tin restricting air flow. You never said what model you have my dad has a R-65 with a water-cooled 4 cyl engine that works great but it needs a rear axle. This would be a great improvement over the wisconsin.
