Wisconsin AEN
steve
03-27-2003 17:49:39
looking for complete carb, any suggestions where to look? Thanks in advance.
Zira
03-28-2003 15:45:56
 Re: wisconsin AEN in reply to steve, 03-27-2003 17:49:39
If you are looking for a new carb, that migt be difficult. You can go with the newer zinc/pot-metal type (L-63E) from teh AENL, but you will need to change your air cleaner mount - the cast iron carbs are slightly smaller around on the outside than the pot metal ones. Some guy sells these on e-bay regularly, or you can try a dealer.
Used, the same basic carb was used on a bunch of motors, not just Wisconsin's. Almost any L-48 carb can be modified to work, but somre are better than others. If you need specific numbers, e-mail me offline or see a dealer.
Good luck either way, let me know if I can help.
steve
03-28-2003 17:12:08
 Re: Re: wisconsin AEN in reply to Zira, 03-28-2003 15:45:56
Thanks for the input I am following one other lead,if that doesn't work I may be in touch,also need an air cleaner so try to get a match
