JD type E 1-1/2
Dick C
03-27-2003 16:50:15
Recently purchased a 1-1/2 HP disassembled and am now acquiring missing parts and starting to put it back together again. Two questions. First, does the flange on the main bearing mount to the inside of the case or the outside? Second: What type of seal fits around the magneto drive gear to prevent oil from being thrown out?
Thanks,
Si
04-06-2003 16:44:51
 Re: JD type E 1-1/2 in reply to Dick C, 03-27-2003 16:50:15
Read my article in GEM Oct.1994 page 37 for how to leak proof a JD E 1 1/2 Magneto shaft. I've done several and none leak. Works on the 3 hp also.
Contact me, and arrange for me do do it, or do it yourself. Address in the article.
DON BRYANT
02-14-2006 20:22:46
 Re: Re: JD type E 1-1/2 in reply to Si, 04-06-2003 16:44:51
HI I WAS WANTING TO KNOW HOW TO RESEAL THE MAG THE REASON I HAVE A 1923 JD E 1 1/2 THE UPPER CRANK CASE COVER DOSENT HAVE A VENT AND IT BLOWS OIL AROUND THE MAD AREA LEAKS DOWN THE SIDE PRETTY GOOD I HAVE ADDED A PIPE ABOUT 10 INCHES LONG WITH A BREATHER DIDNT SEEM TO HELP IT LEAKS SLIGHTLY AROUND BEARING BUT NOT THAT BAD IT RUNS DOWN FROM MAG AREA PRETTY GOOD NEAR UPPER COVER AREA SEE IT BLOWING OUT UPON RUNNING THANK YOU FOR ANY HELP HAVE A NICE DAY
Wildbill
03-28-2003 06:32:11
The flange goes to the inside so the crankcase cover can form a seal on it. There is a felt ring that fits between the mag gear and the little cover between the gear and the mag. I use silicone under the cover. They are good engines but they are messy and will usually find someplace to blow a little oil out.
