VF4D TO VH4D SWAP
PHIL BROWN
02-07-2003 15:47:41
I HAVE A BOBCAT MODEL 600 WITH A TIRED VF4D ENGINE. AND HAVE BEEN OFFERD A USED RUNNING VH4D AS A REPLACEMENT. WILL IT FIT? ALSO THE NEW ENGINE HAS ONLY A HAND CRANK. WILL MY ELECTRIC STARTER FIT THE NEW ENGINE ALONG WITH HYDRAULIC
PUMP.
REGARDS PHIL.
Steve-Maine
02-09-2003 03:14:56
 Re: VF4D TO VH4D SWAP in reply to PHIL BROWN, 02-07-2003 15:47:41
According to my Wisc book the parts are interchangable except if the hyd pump drives off the back of distr. Then you would have to use idler gear from old engine as it is heavier duty. Hope this helps you out.
