WISCONSIN THD OIL THROUGH THE INTAKE
TROY
02-03-2003 17:28:03
I HAVE A THD THAT PUIKES OIL OUT THE INTAKE EVERY NOW AND THEN. WHATS THE FIX????? ???
THANX FOR THE HELP.
TROY
havvey
02-06-2003 18:45:31
 Re: WISCONSIN THD OIL THROUGH THE INTAKE in reply to TROY, 02-03-2003 17:28:03
i would make sure the air cleaner is clean do compression tests air test the cylinders and look at my plugs for sings of the condition of engine sounds like oil is getting into the top somehow valve guides were known to wear on a wisconsin too
Mark IL.
02-18-2003 15:30:25
 Re: Re: WISCONSIN THD OIL THROUGH THE INTAKE in reply to havvey, 02-06-2003 18:45:31
Make sure the line from the governor isnt plugged
with gray goo....
