Waukesha head gasket needed
Mike Kelly
01-31-2003 06:51:28
Hello from Australia , I have a WW2 vintage IR mobile compressor which is driven by a Waukesha 4 cyl side valve engine of 3 5/8" bore and 4 1/2" stroke , it is a H164K model. It has magneto ignition and a hand crank start .
I need a head gasket , I have lots of new manifold gaskets for this engine so I would swap .
The IR compressor is a 3 cyl 100 CFM model , it has " INGERSOLL RAND NEW YORK" cast accross the radiator top tank . I have a manual for a similar post WW2 IR compressor but I would like the correct manual
Thanks from Mike Kelly [email protected]
Larry from MD.
01-31-2003 15:20:13
 Re: Waukesha head gasket needed in reply to Mike Kelly, 01-31-2003 06:51:28
Over here we would call that engine a model XAH.New ones might still be available from arrow.I have a friend who has a new but old head and gasket + other stuff.If you look for a XAH gasket you might find it.
Dietrich Gerber
04-07-2003 12:58:14
 Re: Re: Waukesha head gasket needed in reply to Larry from MD., 01-31-2003 15:20:13
hi I am also looking for a headgasket and a crank shaft. I from South Africa and don't know "arrow" Please can you help? tanks
dietrich
