VF4
Dave
12-30-2002 11:38:00
In need of a Wisconsin VF4, tapered shaft, used in a Bobcat 600. I have a blown one, and looking for a second for 1 out of 2, or a fair running engine/replacement. Thanks.
Sam
01-01-2003 06:55:33
 Re: VF4 in reply to Dave, 12-30-2002 11:38:00
The tapered crankshaft makes this a pretty special application. One possibility is to look at engines used for direct-drive applications, such as pumps, compressors, and generators. They may have used the same type of crankshaft. If you can't locate one of the tapered cranks, you might consider modifying a crank with a straight end, which are more common.
A reasonably skilled person on a lathe could take a crank with a straight shaft and cut the taper, trim to length, and drill and tap for the retainer bolt. The keyway could be cut on a milling machine.
When I rebuilt my 600, I noticed that the taper on the pulley end was the same as the taper on the flywheel end. If your orginal crankshaft is missing or severely damaged, this would be a good reference for the machinist.
John Kelly
01-31-2003 17:28:55
 Re: Re: VF4 in reply to Sam, 01-01-2003 06:55:33
A good start
But Be sure when you reassemble the engine
with your re-ground crank or factory replacement
That You Use The Proper Hardened Gears, or the engine will chew up the soft factory gears.
Been There Done That..
Scott
12-15-2003 21:03:03
 Re: Re: Re: VF4 in reply to John Kelly, 01-31-2003 17:28:55
Could anyone describe what gears John was talking about.I am in the process of having a VH4D crank turned down to replace a VF4D tapered crank and do not want any surprises.
