Wisconsin tf
chad
12-12-2002 07:42:02
I have a wisconsin type tf engine on a lincoln welder. I a wandering if anyone can tell me how to time the mag to the engine. The impulse coupling has a mark on the gear but I can't find one on the engine.
Steve-Maine
12-12-2002 11:39:25
 Re: wisconsin tf in reply to chad, 12-12-2002 07:42:02
According to my manual, the following procedure; Breaker points on mag should be set at .015inch. To install magneto to engine, make certain number "1" cylinder (cylinder nearest flywheel side of engine) is at top dead center on compression stroke, remove air intake screen at flywheel amnd timing hole plug on timing gear cover. Leading edge of flywheel vane marked X and DC should be in register with static timing mark on air shroud. Before mounting magneto in place, turn drive gear clockwise until inpulse coupling snaps, align one number one firing position.Install mag so X marked tooth appears in timing port. To set timing, connect timing light and with engine running slightly above 2000 RPM, timing should be set at 27 degrees BTDC. Hope this helps you out.
Steve
