VH4D
PAQ
11-05-2002 12:01:29
This VH4D runs a Hesston mowing machine from the 60's. Should this engine have a higher compression than 65 to 70 pounds? What kind of ordeal is it to rebuild it if it needs it? What is the best source for parts. Just ordered the manual. Any help would be appreciated.
Thanks!
Milton
01-07-2004 03:45:25
 Re: VH4D in reply to PAQ, 11-05-2002 12:01:29
I also have a wisconsin vh4d engine with the same compression as the one you mentioned. This seems low to me, the manual i purchased does not state a normal compression, all it states is that compression will vary on engines. Should you find a normal compression i would be interested in knowing,
Josh
02-14-2003 16:56:48
PAQ, I have a Hesston SWather with a VH4D engine and I cant find a Model Number just a serial Number. Maybe you can help me figure out the mdel of this machine . I have a picture of it located on the HELP IDENTIFY section of this site. If you could take a look and let me know what you think I would appreciate it very much. Thanks Josh in Oregon
Benjamin J.''Joe Browning
11-05-2002 18:27:36
I'm also in the process of rebuilding a VH4D engine. So far not a lot of trouble as I'm still in the tearing down stage. The factory book is pretty good about walking you through the steps. I contacted the factory and they quoted a total of around $700 for all the parts for a complete rebuild. As it stands right now with mine it looks like a gasket set and maybe new exhaust valves.Also I might need rings. This will run with the valve grinding under $400. This is not bad for a engine that the factory wants $2250 plus a core charge of $1000 for a factory rebuild
Steve
11-06-2002 15:48:28
 Re: Re: VH4D in reply to Benjamin J.''Joe Browning, 11-05-2002 18:27:36
I found a company in New York State that has good supply of parts great service and very low prices. www.northeastmachine.com
ronald rackal
04-05-2003 10:47:55
 Re: Re: Re: VH4D in reply to Steve, 11-06-2002 15:48:28
need parts cam shaft- crank shaft bearrings
