Wisconsin engine id needed
Paul Fillmore
10-24-2002 17:56:51
I need to identify a Wisconsin single cylinder horizontal shaft engine off of a small crawler dozer. Someone kindly removed the data plate and without the model number the local dealer wont even look in his books. Not very friendly. It has a 3" bore and a 3 1/4" stroke. Maganeto is a Wico XH-150C. Head has casting number AB-63-E. Block casting number is BA-5H. The carb is a Zenith L48H 10535A. The head gasket bears the numbers QD-484. The cam has the casting numbers of EA-98-C or might be EA-980. I've been told this is an 8hp, 9hp and 12hp engine but believe it is much less or real tired. It still runs. Any ideas as to it model number would help us to give it a new lease on life.
ANDY VIGIL
12-03-2002 12:39:39
 Re: Wisconsin engine id needed in reply to Paul Fillmore, 10-24-2002 17:56:51
I need to identify a motor with the block number BA49A, it is 4 cylinders and the distributor is on the generator.No other noticible id.
Louie Edwards
02-18-2005 20:27:03
 Re: Re: Wisconsin engine id needed in reply to ANDY VIGIL, 12-03-2002 12:39:39
did you ever fine the ID info on the Engine. I have an engine with the same ID and nothing else.
BA-49A with a 2 under the #. and a U with an F connected to the right side of the U.
Zira
10-25-2002 15:45:37
Your motor is an AEH, 6.2 hp (hard to believe given the size & weight). Let me know if you need any help or info.
David
Paul Fillmore
10-25-2002 18:27:07
 Re: Re: Wisconsin engine id needed in reply to Zira, 10-25-2002 15:45:37
Thanks for the id. Was hoping that it was an 8hp but I guess that explains why it is a bit underpowered. Thanks again
Zira
10-26-2002 17:12:55
 Re: Re: Re: Wisconsin engine id needed in reply to Paul Fillmore, 10-25-2002 18:27:07
If you like that style of Wisconsin, an AGH or the more common AHH (3-5/8" bore X 4" stroke) would both be over 8 hp. The newer AEN or AENL would also, or the newer still S-8D, S-10D, S-12D, & S-14D, or the TR-10 or TRA-10 tractor motors. All of teh newe ones except the S-12D & S-14 D would be smaller & lighter as well. FOr that matter, a BKN that make 7.2 hp is a very good motor & a lot smaller than your AEH, if you are not trying to maintain a "period" appearence. E-mail me off line if I can help.
David
Paul Fillmore
10-26-2002 21:35:32
 Re: Re: Re: Re: Wisconsin engine id needed in reply to Zira, 10-26-2002 17:12:55
What is the real difference between the AEH and the AEN if they both have the same bore & stroke?
Since the cooling shroud is pretty beat up and will take some sheet metal work, It will probably go back to work driving a water pump. Have a lead on a 14 hp engine but the guy doesn't remember what make. With my luck it will be older than the AEH!
Thanks again for the info.
Benjamin J.''Joe Browning
10-24-2002 19:21:37
I had a similar problem. I called the Wisconsin factory. I got their number off their website. They were able to easily "ID" my engine off the casting and other info. Hope this helps. Joe
