Belt driven governer
TimC
10-17-2002 19:27:44
Can anyone give me any lead on where I can get a belt driven governer. What I want is, what did they come on? Would like to get one from a junkyard. Don't want to buy a new one or oem replacement.
I need to limit a motor to about 4000 rpms.
Craig M. DeLong
10-26-2002 10:23:49
 Re: Belt driven governer in reply to TimC, 10-17-2002 19:27:44
Tim..... .check the new Surplus Center catalog or their # 800-488-3407. They list one that you could adapt for $28.95. Item # is 28-1201. C. DeLong
Brian
10-18-2002 23:32:30
Hi Tim, Could you post your email address. I have a belt driven governor that I would be willing to get rid of. Brian from MN
TimC
10-20-2002 09:46:19
 Re: Re: Belt driven governer in reply to Brian, 10-18-2002 23:32:30
Thanks
ax
10-18-2002 23:30:35
test
poorerbut
10-18-2002 05:47:20
Tim: I don't know what engine you want to apply
this to, but a lot of old Massey Harris combines
that had the six cylinder Chrysler flatheads, used
a belt-driven Pierce governor that might work.
This might give you a starting point at least.
Rick
TimC
10-18-2002 06:28:08
 Re: Re: Belt driven governer in reply to poorerbut, 10-18-2002 05:47:20
Thanks, thats a start.
Neil Mullins
12-09-2002 16:29:31
 Re: Re: Re: Belt driven governer in reply to TimC, 10-18-2002 06:28:08
if it's for a smaller engine some Gravely tractors had a belt driven gov on them
Steve
10-18-2002 04:08:46
What engine are you using? You could try Hoff Mfg. Co. at 312-767-6200. Maybe they could tell you correct one for your engine.
Steve
TimC
10-18-2002 06:20:40
 Re: Re: Belt driven governer in reply to Steve, 10-18-2002 04:08:46
The engine i want to put it on was designed to have a vacume governer. I want a mechanical one.
I can make anything work as long as i don't have to start from scratch and build one. Too time consuming.
