Stromberg Carburetor on V4 Wisconsin
John
09-19-2002 09:23:15
Where can i get a carburetor kit for a Stromberg Carburetor on a V4 wisconsin. This engine has a lincoln 225 welder, and has cast block and heads the serial number is 1,113,965. Acording to a book i have it is a 1948 model engine. Every one i have talked to says that it would be hard to get parts for this make carburetor. What other carburetors will fit this engine. Thanks
JAMES LEWIS
04-07-2003 07:16:21
 Re: Stromberg Carburetor on V4 Wisconsin in reply to John, 09-19-2002 09:23:15
IF YOU HAVE NOT FOUND A KIT YET PLEASE GET THE ENGINE MODEL & SPEC NUMBER AND ANY NUMBERS YOU CAN FIND ON THE CARBURETOR AND I'LL SEE WHAT'S STILL AVAILABLE. THANKS,
JAMES LEWIS
poorerbut
09-19-2002 11:09:53
John: If you can identify the model, you might be
able to find it thru this site (if I can post it)
www.cfiworld.com/everythingcarbs/antique/carb-id-num/stromberg.htm
Maybe this will get you in the ballpark.
Lots of luck. Rick
Steve
09-19-2002 17:11:17
 Re: Re: Stromberg Carburetor on V4 Wisconsin in reply to poorerbut, 09-19-2002 11:09:53
You might try a NAPA store, they have a good supply of industrial carb kits
