THD Wisconsin engine
Tom
09-08-2002 19:46:56
I got a two cylinder Wis engine and the fuel pump will not work with the hand primer lever it will not pump fuel you can take it off and pump by hand and it will work or take out the hand lever and pump it with a screwdriver and it will pump have put on 3 new pumps from Wisconsin and they all work the same When the engine is running it will not run long because the pump will not supply enough fuel Any help would be appreciated. Thanks Tom
Terry
01-11-2003 18:00:20
 Re: THD Wisconsin engine in reply to Tom, 09-08-2002 19:46:56
Hi, I just started working on a Wisconsin THD. I had read about your problem before working on my fuel pump. I purchased a new fuel pump and had similar problems. I checked everything. It so happened that I had a rebuild kit for the fuel pump so I installed it in the Brand New Fuel Pump and it started working. I also checked all my lines and fittings. Pumps like crazy. Hope it stays that way.
The pump I installed has different valves in it compared to the old pump. The old pump had small fiber board disks in it. The new pump used rubber washers. I will run it a while an make sure it stays working. Regards, Terry
Larry from Maryland
09-11-2002 16:36:49
It sounds like the cam is not moveing the lever.It could be worn off,or the lever is not touching it.
David Stobbart
09-10-2002 15:34:39
I had similar problems but with a different model motor. Gave up in the end and simply fitted a electronic fuel pump.
Regards David S
VERA
09-14-2002 15:37:35
 Re: Re: THD Wisconsin engine in reply to David Stobbart, 09-10-2002 15:34:39
I would say to follow the gas line all the way to the tank double check all your fittings ,make sure your not sucking air some place,and check the screen in the tank
