Stuck IHC 1-1/2 hp Model M Piston
RICK
08-22-2002 10:17:26
I have a 1930 1-1/2 hp IHC Model M with a stuck piston. I've taken off the head and access panel to the crank and sprayed every thing down with Kroil,plus let Kerosene soak in the cylinder bore for a month but nothing loosened up. I then loosened up the crank mounts on each side of the body and the crank and rod had play so I've narrowed it down to the piston. Even with my 280lb jumping on the flywheel it won't budge. What can I try next?
bob
08-23-2002 13:42:50
 Re: Stuck IHC 1-1/2 hp Model M Piston in reply to RICK, 08-22-2002 10:17:26
Rick, Set it on end, pour a cup of brake fluid or kerosene in the cylinder, stick an old sock in the cylinder for a wick, and light it. keep adding fuel until the cylinder is fairly hot, then let it cool. Repeat this a few times, and pretty soon the heating and cooling cycles will have broken it loose.
Loren Pribyl
08-22-2002 14:06:08
I use Iron Etch, made by Martin Seynour, which I buy at NAPA. It's a blueish color acid solution used for paint prep. Clean up the cylinder and top of the piston, then stand to motor up so the piston is upward and pour about a 1/4" of iron etch into the cylinder. Let it sit overnight, and next day pound the piston down with a block of wood against it. We've used this method on a 1 1/2HP Fairbanks engine that was stuck, as well as several stuck tractor pistons, and it has worked every time. After the piston starts to move, you can then take a narrow piece of wood and drive it out from the back side. The iron etch may leave a slightly rough surface on the cylinder where the solution sat, but it can be honed out.
I'm working on a 1 1/2 HP "M" engine now. It was loose, but not running. I took the entire engine apart and am sandblasting all of the parts now to paint it. Hope to have it back together and running this fall. Let me know if you run into any other problems dis-assembling it.
