Waukesha engine info
Levi S
07-03-2002 16:42:20
I was wondering where I could find information on older Waukesha engines.
I have an older flathead 4 cylinder Waukesha engine (Model: 1CKU 5057L) with a "Twin Disc" (Spec No. 15384 Mod. No. C-107-SP5) clutch system attached to it.
Are parts still available for Waukesha engines?
Hel Pless
12-27-2004 17:22:43
 Re: Waukesha engine info in reply to Levi S, 07-03-2002 16:42:20
I need parts for a Waukesha engine 3 1/4 x 4. Model: FC-333-E Gov. Speed: 220010ADED. I really need an overhaul kit but also possibly needs a carb. This engine is a four cylinder in a 1950s model Hough Payloader Model HAH. If you have any info. please reply. Thanks
roy raymond
06-23-2005 16:16:04
 Re: Waukesha engine info in reply to Hel Pless, 12-27-2004 17:22:43
How did you make out with the waukesha engine? Do you have any info on the transmission and torque converter in the same hough hah?
John Hilger
02-08-2004 10:41:20
Hi Earl, I am interrested in getting some tune up info on the Waukesha engine. I have a Model FC,
size 3 1/4 x 4, Spec G-15862, Ser. 127 325.
Distributor: Delco Remy, # 625 F 6 M15.
It drives a 200A Harnishfeger welder.
I just ordered the tune up kit for the engine, but they cannot help me with the specifications.
Any help or info you can give me would be greatly appreciated. Thank you in advance, John.
P.S. Cannot find a timing pointer either.
sid conner
01-26-2003 14:19:32
I'm also searching for information regarding what automobiles may have used early 4 cyl. Waukesha engines (prior to 1920)
Seamo
07-03-2002 19:00:41
Yes, what do you need? Earl
dan brown
05-28-2003 16:01:57
 Re: Re: Waukesha engine info in reply to Seamo, 07-03-2002 19:00:41
i need a water punp for a model fc no. 16897 G2554. it is a 1938 payloader made by hough thanks dan
Levi
07-03-2002 20:22:59
third party image
I just remembered that I had a picture of this unit. It's been painted over several times, so I don't know what the original color of it was.
