LeRoi Power Unit
Jerry
06-09-2002 06:30:23
Am looking for information on a LeRoi power unit that may have come off a gleaner combine. It is a 4 cylinder with 3 3/4" bore and 4" stoke. It has a gear driven generator, starter and clutch unit with a bevel gear on the output shaft. It has overhead valves. Any information would be greatly appreciated. Thanks.
Jerry
06-09-2002 06:39:17
 Re: LeRoi Power Unit in reply to Jerry, 06-09-2002 06:30:23
My e-mail address was incorrect on original message. This one is correct.
greensboro george
07-26-2002 10:32:54
 Re: Re: LeRoi Power Unit in reply to Jerry, 06-09-2002 06:39:17
Hey Jerry:
I just bought a Le Roi 125 trailer mounted air compressor and found a little info at www.tractair.com. They have some diagrams and specifications. I have to check mine out to see what els I can find out. I think it was built in the early 60's 4cyl 226 cu in engine. 2 cylinders fire and the other two pump air at the rate of 125 cfm. It has sat in a barn for 5 or so years I will get it running this weekend. I will pass on any other info I get
