Kohler Magnum Twin Cylinder
farmerjoe
05-25-2002 09:28:53
New rings,valve guides,but crankcase has excessive pressure.Vent sysytem is ok.Any ideas?Appreciate any help.
Don Young
06-10-2002 21:45:07
 Re: Kohler Magnum Twin Cylinder in reply to farmerjoe, 05-25-2002 09:28:53
I am not familiar with your particular engine but if you are sure the vent system is okay the only other cause of excess crankcase pressure is blowby past the piston rings. This might be caused by excessive ring gap, rings damaged or incorrectly installed, or failure of the rings to seat due to cylinder wall finish being too rough or too smooth (glazed). An unsuitable break-in oil or break-in procedure might delay ring seating. If this happened after some running, a hole burned through the piston head might be possible. Any of these should be detectable by a compression check. Hope this helps, Don
