Junkers diesel
Leigh Barnes
03-27-2002 05:17:06
i have a single cylinder two piston junkers engine it has three conrods withpumping chamber on to bore is 2 1/2 inches it stand 3 feet tall and is 3 feet long its water cooled does anyone know its build date Roughly and Hiorsepower Rating HP? Revs Thankz Leigh
christian
03-28-2002 01:37:10
 Re: Junkers diesel in reply to Leigh Barnes , 03-27-2002 05:17:06
Hi Leigh!
Looks like it is a 1HK65 model. Bore 65mm, stroke 90 + 120mm for upper and lower piston. Maximum power is 12,5hp at 1500rpm, but you could also get 1000 or 1200rpm, depending on the governor springs and weights. They were manufactured in Scharfenstein and Chemnitz (East Germany) from 1934 on up to the end of WW2, and then again in Karl-Marx-Stadt (former Chemnitz....and now again)up to the 70s and in Munich up to the middle 50s.
Hope this helps.
Greetings! Christian
Jeff Holly
06-19-2003 17:56:01
 Re: Re: Junkers diesel in reply to christian, 03-28-2002 01:37:10
Hello Christian,
I trust you are still interested in replying after a year. I have a couple of friends who have these engines - Junkers HK65 - who are looking for instruction books. Are you able to help here please? There are a few in Australia.
Sincerely,
Jeff.
