LE ROI POWER PLANT
MONGO
03-26-2002 18:55:08
CAN ANYONE GIVE ME ANY INFO ON A 1943 LE ROI ELECTRIC PLANT. IT HAS A LE ROI ENGINE, WESTINGHOUSE GEN. 25KW, 120 VOLT. THIS THING IS HUGE. CAME FROM OUR LOCAL AIRPORT. WAS INSTALLED 1943 BUY THE US ARMY CORPS OF ENGINERS FOR STAND BY LIGHTING.THE UNIT WAS INSTALLED BY WESTERN ELRCTRIC. THANKS MARK ANGLE
Allen, Jewell
07-10-2005 11:28:56
 Re: LE ROI POWER PLANT in reply to MONGO, 03-26-2002 18:55:08
Does Anyone anything about a leroi engine with the serial Number 25x14419? I have a friend that has one but does not know what it went it before he got it. Any info would be great. Thanks again
Allen.
Fluhart
06-14-2005 11:56:29
Hello,
I've got 2 Le Roi L3000 V-12 3006 cubic inch engines with E-M 175kw 2400v generators on ebay if anyone is interested. To view, go to ebay and type the item number (7523669372) in the search box. -Nicholas
Robert Ward
05-06-2005 04:03:20
Mongo,
I was wrong when I said that your genset was a PE-84. It should be a PE-145. The PE-145 and PE-84 are identical except for the output. The PE-145 puts out a straight 120V, single phase where the PE-84 puts out 3 phase 220V. They each weight around 5000 pounds shipping weight.
Robert Ward
05-05-2005 15:50:46
Mongo,
I have the same thing. It's a PE-84 and runs at 900 RPM. I have a TM on the machine I can make a copy of if you need one.
Tim Peltier
03-11-2004 22:59:01
I have one complete Leroi Power Plant I'm looking to sell. Are you interested? Tim
Robert Ward
05-10-2005 04:23:28
 Re: Re: LE ROI POWER PLANT in reply to Tim Peltier, 03-11-2004 22:59:01
Tim,
I saw your post and I know it is old, but, did you still have your Le Roi power plant? What model is it? Is it still for sale?
Fluhart
06-14-2005 12:01:37
 Re: Re: LE ROI POWER PLANT in reply to Robert Ward, 05-10-2005 04:23:28
Hello,
I've got a couple of Le Roi power units I am trying to sell. They are L3000 V-12 units with E-M 175kw 2400v generators. They are currently on ebay as of 6/14/05. To view, go to ebay and type the item number (7523669372) into the search box.
Robert Ward
05-05-2005 15:45:25
How much and where are you located? I'm in Illinois.
John Manning
08-07-2002 20:35:32
I have 4 of the same engine-gen sets and am desperately trying to locate water pumps for the Leroi engines.
As far as their history: during WWII, the gov't contracted for back area and communication "light plants" and Westinghouse won the generator contract and Leroi won the engine contract (with Westinghouse later buying out Leroi to more easily fulfill the contract); the engine that Leroi developed and the generator that Westinghouse delveloped for this contract were made only for each other and no other applications exsited for these 2 components (i.e., the egine was made for that particular generator and that generator was made for that particular engine and nothing else).
Robert Ward
05-05-2005 16:03:15
 Re: Re: LE ROI POWER PLANT in reply to John Manning, 08-07-2002 20:35:32
John,
You may have to resort to rebuilding the existing water pumps. Since this engine used a split pully as a built tensioner, you'll require a spanner wrench to loosen the pully halves to get the belt off. I could look in my parts book to see if I can still match up any bearings and seals, but you won't know for sure until you take the pump apart.
Duff Matson
12-08-2002 17:47:27
I am trying to restore a 2 cyl, water cooled stationary Le Roi #51971 ,on mag side has 1-39 on block.Any idea as to where I can find a manual?
Thanks
