IH LB timeing
Andrew Helm
03-18-2002 20:14:39
I pulled the mag out of my LB engine thinking it was like a tractor and could olny be half off but I found out it was geared and I can not find a timeing mark on the mag gear or the gear in the engine I was wondering if anyone knew how to time it thanks
Andrew Helm
Red Raider
03-19-2002 18:39:54
 Re: IH LB timeing in reply to Andrew Helm, 03-18-2002 20:14:39
The hard way would be to line up the flywheel TDC (compression stroke) mark to the index mark on the engine, grab the mag and rotate the gear to just before the impulse spring grabs, then try and mesh the gears. It will be trial and error to get the mag to trip at TDC. You may have to repeat the process several times trying slight repositioning of the flywheel. NEVER time the spark to occur before TDC on this or any other engine.
Third Party Image
