Valve timing B700 Clinton 2HP
Paul Traviss
03-12-2002 15:40:27
Rebuilding B700 Clinton. Can not find any timing marks on cam gear or on crankshaft. Any ideas?
LynMn
03-20-2002 18:40:14
 Re: Valve timing B700 Clinton 2HP in reply to Paul Traviss, 03-12-2002 15:40:27
Assemble the valve system,with valve clearance
set .010 to.012 when lifter is on low side of
cam lobe. Now turn camshaft till one valve is just opening and the other valve is just closeing, at this point the camshaft will not
roll back or forth without some force.
Install the crankshaft so piston will be at top dead center. Thats it. .010-.012 is correct running clearance.
Paul Traviss
03-25-2002 14:23:06
 Re: Re: Valve timing B700 Clinton 2HP in reply to LynMn, 03-20-2002 18:40:14
Thank you for the info.Clinton hasn't sounded so good in years.Runs great.
Paul Traviss
03-12-2002 18:11:58
Sorry folks. New to this computer business.The kids tell me the e-mail is .ca and not as first posted.I'm a little better with engines but would still appreciate any help with timing this one.
