International lb
scott
04-21-2001 21:31:42
Does the fuel line check valve have to be inplace for the engine to run?
kelvin kaddatz
04-23-2001 19:49:20
 Re: international lb in reply to scott, 04-21-2001 21:31:42
The check valve isn't needed to RUN the lb. But you will find it a lot easier to start the engine. The check valve keeps the gas up to the carb. Otherwise the gas runs back into the tank and the engine has to suck the gas up in order to start everytime. That's a lot of cranking in order to get the gas up to start everytime. I just bought a check valve from Hit & Miss enterprises for a LB for $14.95 and it works great.
scott
04-23-2001 20:12:57
 Re: Re: international lb in reply to kelvin kaddatz, 04-23-2001 19:49:20
Thanx, I just ordered one today from them.
ED HERRICK
04-22-2001 18:55:57
SCOTT
I believe that the check valve has to be in place. I have 1 1/2 lb and the previous owner told me that if it would not start that I should check the check valve. Good luck
scott
04-22-2001 19:04:08
 Re: Re: international lb in reply to ED HERRICK, 04-22-2001 18:55:57
thanx Ed, that's what I was afraid of. I dont have that part.
ed herrick
04-23-2001 04:50:42
 Re: Re: Re: international lb in reply to scott, 04-22-2001 19:04:08
Hello Scott
I do not know if you look at this website but you could probably find one here>Link
Good>Link luck
