18hp BS problems!
Presley Thompso
01-28-2001 07:09:02
I have a older 18hp B&S. The motor will run but will not idle. You can not start it with out pouring gas down the carb. What can be done to make it idle. E-mail me
Kent David Redd
09-20-2003 10:04:46
 Re: 18hp BS problems! in reply to Presley Thompson, 01-28-2001 07:09:02
Check the idle mixture screw to see if someone did not tighten it to tight and break off the tip
in the idle mixture hole in the body of the carb.
What is the model number of this engine?
