Wico Mag
Red Raider
01-08-2001 10:39:53
I've got an IHC LA and need to know if the mag keeps its magnetic field over a long period of inactivity. I know it has been over 40 years since the LA has been used. Do they need to be reenergized or polarized? I'm just about to tear into the engine for a complete restoration.
third party image
Rick
04-30-2001 17:45:14
 Re: Wico Mag in reply to Red Raider, 01-08-2001 10:39:53
I just finished a LB that hadn't run in about 25 years. All we had to do with the mag was to clean the points, check the condenser, and set the points at about .015. Good luck Rick
John C.
01-11-2001 06:46:47
The magnet on this type of magneto is not likely to lose its power from years of inactivity, unlike the horseshoe magnet-type magnetos of the older engines. If the primary coil has been protected from the elements, I would clean and gap the points first, and then see if it throws a spark.
Steve
01-09-2001 02:52:07
If the spark does not appear strong and have a blue tint to it a rebuild is probably a safe bet.
You can get some info on doing it yourself from a couple different sites on the web. Try a search for magnetoes. I bit the bullet and sent my last engine mag to Branson and was very pleased with the quick service, price and it worked great when I installed on the engine.
William G. Miller
09-28-2002 17:24:22
 Re: Re: Wico Mag in reply to Steve, 01-09-2001 02:52:07
Hi Steve this is Guellermo in Arizona. Having probs with mag on Cont A-75. Old slick. Question: What other mags will fit? What price should I expect to pay? Are the others rebuidable at a reasonable price? Thank you for your help!
