Help identify Maytag - worth rebuilding?
Steven f/AZ
03-08-2008 18:52:36
Bought this old Maytag on a homemade tiller last summer... thought it was too interesting to pass up since it was loose and the owner claimed it had ran not too long ago...
All the bolts were loose when I took it apart, so who knows if it ever ran. Going to need plenty of parts to get it going, kinda wondering if it's even worth going through the trouble. The crankshaft and rod are grooved pretty deeply.
Any ideas what model it is? Or are there numbers somewhere under the grease that will help me out?
third party image
third party image
third party image
third party image
third party image
third party image
third party image
third party image
third party image
third party image
third party image
Steven f/AZ
03-14-2008 07:27:15
 Re: Help identify Maytag - worth rebuilding? in reply to Steven f/AZ, 03-08-2008 18:52:36
Got the steel ring off the flywheel and found the serial number - 495111, which I believe makes it built in May 1933. Had no idea that these were that old!
Getting some manuals, a flywheel, and a connecting rod so far. Bidding on a crankshaft on eBay that looks much better than mine.
I figure I'll try the crankshaft before worrying about the main bushings. If those are too loose I'll have to see if there is a local machine shop willing to do the work.
These are a fair amount cheaper to work on than the old tractors I'm used to! Guess I'll have to find myself a twin somewhere now...
Thanks for all the help!
Steven f/AZ
03-09-2008 17:06:46
 Re: Help identify Maytag - worth rebuilding? in reply to jdemaris, 03-08-2008 18:52:36
Tinker In TN said: (quoted from post at 20:20:33 03/08/08) It's a model 92 Maytag. Parts are easy to find. The homemade cultivator is a neat find. I'd keep the whole unit, and display it as a one-of-a-kind item.
Thanks for the info... any ideas on where to find parts? The flywheel has been broken and poorly repaired with a strap, and I'll need gaskets, etc. to get it running.
Tinker In TN
03-09-2008 18:31:10
 Re: Help identify Maytag - worth rebuilding? in reply to Steven f/AZ, 03-09-2008 17:06:46
Anything you need.
http://www.maytagshed.com/
Vern-MI
03-11-2008 14:50:21
 Re: Help identify Maytag - worth rebuilding? in reply to Tinker In TN, 03-09-2008 18:31:10
There are quite a few parts on EBAY.
The Maytag service manual can be found here...
Tinker In TN
03-08-2008 19:20:33
Vern-MI
03-11-2008 11:58:56
 Re: Help identify Maytag - worth rebuilding? in reply to Tinker In TN, 03-08-2008 19:20:33
The serial number is stamped on the outer face of the aluminum flywheel under that steel strap. The steel strap is something that a previous owner made and bolted on for some reason.
The crank doesn't really look that bad in the photo. The bushings are probably worn worse than the crank journals.
Ebbsspeed
03-28-2008 12:45:05
 Re: Help identify Maytag - worth rebuilding? in reply to Vern-MI, 03-11-2008 11:58:56
Looks like that steel strap is on there to hold the flywheel together. Looks like there is a chunk of aluminum missing on one section of the flywheel....
Steven f/AZ
03-29-2008 17:59:39
 Re: Help identify Maytag - worth rebuilding? in reply to Ebbsspeed, 03-28-2008 12:45:05
Ebbsspeed said: (quoted from post at 12:45:05 03/28/08) Looks like that steel strap is on there to hold the flywheel together. Looks like there is a chunk of aluminum missing on one section of the flywheel....
Yep, and that strap probably threw the whole works out of balance resulting in the ruined crankshaft, bushings, connecting rod, etc.
I'll be using the following parts from "my" engine: piston, cylinder, fuel tank and top, kick pedal and ratchet.
I would have been better off to buy a running engine off eBay or otherwise. :( But this is a hobby and learning experience...
Vern-MI
03-11-2008 11:59:36
More serial numbers....
