Stationary Engines Discussion Forum
need prices of stationary engines
m weller
02-21-2008 12:04:51
had a fire and need repacement cost of stationary engines for insurance company. all engines were rebuilt,in running order, and painted.
john deere "E"2hp
gilson-2hp
ihc "m" 3hp
ihc "M" 4hp
ihc 1 1/2-2
ihc 3-5
fairbanks "Z" 11/2&2
twin tank pep_ _ _?
JT
02-22-2008 18:49:54
 Re: need prices of stationary engines in reply to m weller, 02-21-2008 12:04:51
john deere "E"2hp==if it is a 1 1/2hp - 1000,00-1200.00
gilson-2hp-
ihc "m" 3hp $600.00
ihc "M" 4hp
ihc 1 1/2-2 la=300-350---lb 300;00
ihc 3-5 la=450-500---lb 350-400
fairbanks "Z" 11/2&2 1 1/2=450.00 2hp 500.00 depending on type
twin tank pep_ _ _? These are what I hae seen recently priced atin Illinois
Unfortunatly, unless he had insurnace on these for a set value, he will probably loose his tail on these.
Good luck
Jim
oy
02-21-2008 16:09:51
john deere "E"2hp Didn't make them that size
gilson-2hp
ihc "m" 3hp $600.00
ihc "M" 4hp Weren't made in that size
ihc 1 1/2-2 $200.00
ihc 3-5 $300.00
fairbanks "Z" 11/2&2 $200.00
twin tank pep_ _ _?
Try here. They actually know what's going on.
m weller
02-21-2008 20:05:00
 Re: need prices of stationary engines in reply to oy, 02-21-2008 16:09:51
thanks. im doing this for a friend, he just lost his garage and is pretty upset. will double check on those model numbers.
oy
02-22-2008 18:38:12
 Re: need prices of stationary engines in reply to m weller, 02-21-2008 20:05:00
I can't imagine losing my engines in a fire after the work that goes into restoring them. Do a search here. You should be able to find them all.
the Unforgiven
02-22-2008 04:52:41
Wiscona Pep and the Gilson may be the most desirable, JD made 1 1/2, 3 and 6hp engines, the 1 1/2 about a grand, the 3 will bring $1500-1800ish, the 6hp is real high.
