Stationary Engines Discussion Forum
Service manual
Jim uc
02-16-2008 13:34:40
Hi all,
I`m looking for a service manual for a Briggs &Stratton # 19fb motor spec. 706511 serial# 601661 also an air schroud and backing plate.
Kentb of SWMO
02-17-2008 14:34:25
 Re: Service manual in reply to Jim uc, 02-16-2008 13:34:40
The only service manuel you will most likely find is B&S's " Service Manuel for Out of Production Engines 1919 - 1981 " Check at your local Briggs dealer. It may be out of print as I have had mine about 4 years but they are around. The flywheel shroud is I guess what you call the air shroud is P/N 291280. Backing plate is P/N 291211. Hope this helps. I have a complete set of the number series engines in ungeared PTO. I have one with the 6 to 1 gear box. I do not know if I want to get a complete set with the 6 to 1 gear box.
Kent
Jim uc
02-18-2008 05:19:41
 Re: Service manual in reply to Kentb of SWMO, 02-17-2008 14:34:25
Kent, thanks for the reply. I will see if I have any luck locating parts.
