Stationary Engines Discussion Forum
John Deere Hit Miss
Jerry L /AZ
02-09-2008 14:55:01
A neighbor has a John Deere 1 1/2 hp hit & miss engine .he saw my old tractors and asked if I knew anything about his engine, I told him that I do not, but will try to find out for him. His question is how do you time it, and how do you set the magneto. any help will be great
Thank you Jer
JDMAN
04-16-2008 18:32:03
 Re: John Deere Hit Miss in reply to Jerry L /AZ, 02-09-2008 14:55:01
[q uote="Jerry L /AZ"](reply to post at 15:55:01 02/09/08) [/quote] Jerry in my book I have for JD E AEngines it says Timing Igniter. The igniter must trip when mark SPARK on flywheel is level with or slightly above EXHAUST ROD and exhaust rod is clear back toward flywheel just starting ahead. If igniter trips before this pont, loosen clamp bolts on trip bracket and adjust bracket ahead. Face of igniter trip mst set flat against igniter hammer when bolts are tightened.
JT
02-17-2008 15:40:56
Also if he call Hit N Miss enterprises at (440) 272-5335 they probably have a reproduction about manual for it. John Deere was still selling the manuals 10 years ago, also.
the Unforgiven
02-09-2008 15:54:55
You line up the marks on the crank gear and the cam gear, and the cam gear an mag gear at the same time, the cam gear has two marks and will only line up with the other two in one position. It has marks on the flywheel for spark and exhaust, you want to trip the ignitor when the marks line up with the pushrod, and then turn to the exhaust open mark and have zero valve cleance just when the mark is even with the pushrod.
Vern-MI
02-13-2008 07:01:08
 Re: John Deere Hit Miss in reply to the Unforgiven, 02-09-2008 15:54:55
Quite often there is a small horseshoe shaped clip on the magneto actuating rod that when pulled will retard the spark timing for starting. Once it is running the clip can be pushed back in to allow proper running spark timing.
Jerry L /AZ
02-09-2008 17:50:54
Thank you I'll pass this along.
