Stationary Engines Discussion Forum
Wisconsin aenld not starting
tpohl
11-13-2007 04:02:16
I adjusted the points to the right gap and the spark plug so I am thinking I am getting a good fire. It tries to start when I choke it(One puff). I then slightly open the choke up and it will run 20 seconds(5- 10 puffs). That is as far as I can get. Is my carb needing rebuilt? I know some gas slightly runs out of the carb(I have the air cleaner tube off) when it sit so I am guessing the needle is not sealing. Also when I tried adjust my floats the manual said it should be around 1 3/16" which I tried to do. Any suggestions would be much appreciated.
guido
11-14-2007 16:06:18
 Re: Wisconsin aenld not starting in reply to tpohl, 11-13-2007 04:02:16
Hey TPOHL
To set the float on any carb you have no specification for is easy.
Take the carburator apart, invert the fuel bowl and adj the float level parallel to the bowl. works every time.
GUIDO
tpohl
11-14-2007 20:28:27
 Re: Wisconsin aenld not starting in reply to guido, 11-14-2007 16:06:18
Checked floats they are level. Any others suggestions would be much apprecitated.
