Stationary Engines Discussion Forum
Old Cement Mixer Motor
redlabel6
11-08-2007 06:32:18
Hi everyone, I'm looking at purchasing my first old engine. I found a concrete mixer with an international LA, or LB on it. I'm going out to look at it tomorrow. What should I look for?? He is asking $250.00 for motor and mixer, all I want is the motor. Is there any value other than scrap to the Mixer?
I hope the link works, I posted a picture of it in the impliments section. Thanks!
graemeoldiron.
11-11-2007 14:11:35
 Re: Old Cement Mixer Motor in reply to redlabel6, 11-08-2007 06:32:18
Hi. I see you said I hope its not too addictive, boy you got a shock coming. I started collecting last year. Went to collect my first engines last easter, which grew from 1 (a 2hp sundial open crank) to 7 in the month before I could pick em up. I am about to go pick up a 8hp Tange, this is about 125 I now have collected in 18 mths, about 90 good goers. I have an LB also. Its not REALLY addictive. Good luck and cheers Graeme.
Will in MN
11-08-2007 07:08:17
He's been trying to sell that one for awhile. Must be in tough shape as they usually go fast.
Uncovered like that It could be stuck pretty good or cracked. LA/LB engines are quite common so it's not much use to spend much on a junker. You from around the Twin Cities?
Shakopee is where the mixer is, if I remember right.
redlabel6
11-08-2007 07:16:53
 Re: Old Cement Mixer Motor in reply to Will in MN, 11-08-2007 07:08:17
Yep, from Chaska. the mixer is in Prior Lake somewhere... I'm gonna take a look tomorrow.. I was figuring it might be worth 100 to 150....
Will in MN
11-08-2007 07:23:13
 Re: Old Cement Mixer Motor in reply to redlabel6, 11-08-2007 07:16:53
It would be nice to see a complete unit like that restored instead of scrapped. The mixer looks to be very heavy duty. It would be a shame to see it junked instead of turning it into a working display.
Let me know what you find out. I almost went to look at it myself but got busy. And usually if an engine doesn't sell right away, it's junk.
redlabel6
11-09-2007 16:30:31
 Re: Old Cement Mixer Motor in reply to Will in MN, 11-08-2007 07:23:13
Will,
I went and picked it up this afternoon. I did not buy the entire mixer. It is a very heavy duty unit with the lower section being cast ironm I did see several cracks in it.
The engine was in a lot better shape than I expected. It had been coveredall the time, still has compression, no cracks in the water tank, still has gas in the tank... pretty stinky stuff though. It is a LB engine. Now to get the tank cleaned out, etc. I want to see if I can get it to run before doing too much to it..
Will in MN
11-09-2007 17:00:18
 Re: Old Cement Mixer Motor in reply to redlabel6, 11-09-2007 16:30:31
Glad to hear it worked out. Did he have many people look at it ?
Welcome to the addiction. You know that you can't have just one, right?
Now you need the 3-5 and the LA's etc.
redlabel6
11-09-2007 18:02:52
 Re: Old Cement Mixer Motor in reply to Will in MN, 11-09-2007 17:00:18
He said he had 2 or 3 e-mail him about it, but I was the only one to go look at it..I hope it's not too addicting! I got the raised eyebrows from the better half when she saw it....
Do you have any of these critters? If so, I may need to tap your knowledge....Where in MN are you located?
Will in Mn
11-13-2007 16:18:48
 Re: Old Cement Mixer Motor in reply to redlabel6, 11-09-2007 18:02:52
I have many of those critters.
I can be reached at oldengines58at aoldotcom
redlabel6
11-14-2007 05:40:49
 Re: Old Cement Mixer Motor in reply to Will in Mn, 11-13-2007 16:18:48
Thanks Will! I got it to fire up last night! Now that I know it will run I plan on tearing it down a bit, cleaning it up and repainting. The wife wasn't too happy about me stinking up the house.... Guess I need to take it outside the next time I start it.
Bill D
11-10-2007 11:09:58
Depending on how bad the mixer itself is, you may be able to sell it to a contractor.
