Sterling marine engine.
Jim
09-20-1999 19:22:54
I have aquired an old Sterling marine engine that was connected to a large generator at a municipal water pumping station for use during power failures. It's a large 6 cyl. engine about the size of a large Cummins truck engine. It has hardly any hours on it and runs beautifully. I've heard they were used in tugboats. Can anyone tell me how to learn more about this engine and it's history?
J P Camp
03-23-2001 21:16:24
 Re: Sterling marine engine. in reply to Jim, 09-20-1999 19:22:54
If you are still intrested, I can tell you something about the Vicking II engines. I work on them every day. I know very little about the Dolphins and the Petrels. Sterling Engine Co. was out of Bufalo, N Y. I have access to some of the manuals.
04-03-2000 18:06:25
Kevin Melvin
05-03-2000 01:40:35
 Re: Re: Sterling marine engine. in reply to ., 04-03-2000 18:06:25
Hello, Did you ever find any information on that sterling marine engine? I have a friend that runs a water treatment plant,and he also has an old sterling power plant. This one has't been run in many years. I have often thought it would be nice to get it. But I realy do not know what I would do with it. They are doing a major renovation and will be getting rid of it in the future. Take care Kevin...
Barry Brown
08-06-2000 13:54:37
 Re: Re: Re: Sterling marine engine. in reply to Kevin Melvin, 05-03-2000 01:40:35
I just acquired what sounds like a similar engine although yours sounds in better shape. I know nothing about it's use but can tell you it is fitted with twin updraft schebler carbs and also has 2 plugs per cylinder. I can email you photos if you wish. As far as what I'm going to do with it ... well it's a lovely piece of industrial art!I'd like to aquire some literature on it. Any ideas? What have you learned about yours? thanks, Barry
Ken Liden
08-17-2000 20:50:26
 Re: Re: Re: Re: Sterling marine engine. in reply to Barry Brown, 08-06-2000 13:54:37
I too am interested in the Sterlings as my boat was originally powered by a pair of Viking II engines rated at 600 hp on gas. This was an 83 foot Coast Guard patrol boat.
There have been several 6 cylinder sterling marine engines going back to before 1925.
The Chevron series have a 5.5" bore and 6.75" stroke for 962 cubic inch and were rated @ 35hp@ 400 rpm, 85 hp @ 800 rpm, 130hp @ 1200 rpm, and 150hp @ 1500 rpm. The smaller two weighed 3250 lbs and the others were 2620 lbs.
The Dolphin series are 5.75" bore and 6.75" stroke for 1052 cubic inch and had various ratings ie Dolphin Medium 110 hp & 165 hp @ 800 & 1200 respectivly and 2980 lbs. Dolphin 187 & 225 hp @ 1250 & 1550 respectivly and 2900 lbs, Dolphin Special 275 & 290 hp @ 1750 & 1950 rpm respectivly and 2900 lbs.
Petrel series. Most were 5.25" bore and 6" stroke for 779 cubic inch and were rated 75 & 115 hp @ 800 & 1200, 115 & 145 @ 1200 & 1500, 145 & 180 @1500 & 1800, 180 & 200 @ 1800 & 2100. All were 2050 lbs. There are two other Petrels that are not the same as the previously mentioned.
The smallest Petrel was 4.875" bore and 6" stroke for 672 cubic inch and rated 65 & 125 hp @ 800 & 1500 rpm. The last is the same size as the bigger Petrels but called Petrel Red Gear. It was rated 140 & 190 hp @ 560 & 675 rpm and was 3460 lbs.
Coast Guard series. So called because of there great popularity with the Coast Guard in there 75 foot patrol boats of 1926. They were 6.25" bore and 7.75" stroke for 1427 cubic inch and rated 100 & 225 @ 600 & 1200 rpm, and 225 & 300 @ 1200 & 1500 rpm and were 4700 lbs.
And the last was the Viking II series with 8" bore and 9" stroke for 2714 cubic inch and were rated 125 & 190 hp @ 450 & 600 rpm, 190 & 300 hp @ 600 & 900 rpm, 300 & 425 hp @ 900 & 1200 rpm. They were 8975 lbs.
All of the weights listed are with marine gearbox. Most engines were available with an aluminum crankcase. Most of thier engines were dual overhead camshafts, multiple carburation, multiple ignition, and even two oil pumps.
I believe all of thier engines were gasoline but they did offer some diesel kits for the 8 cylinder Viking II in 1947. I have not been very successful in tracing the history of the company.
Hopes this helps a little. I have a little more info should you wish to e-mail me.
LOL, Ken Liden
Marjorie Bonneville
05-29-2003 18:47:44
 Re: Re: Re: Re: Re: Sterling marine engine. in reply to Ken Liden, 08-17-2000 20:50:26
I see that it has been 2 years since this was discussed but I came across it while searching Sterling Marine Engines. My friend has a vintage completely overhauled 1945 Petrel Marine Engine for sale. He has done the work on it himself and knows quite a bit about the engine if anyone out there still has questions that maybe he could help them with. I am trying to find out where to market this engine for him. Any help would be appreciated.
J P
05-03-2001 17:32:43
Ken I have working knolage of the Viking II ( T C 8 )engines. I would like to know more about the earlier engines. I do know that Sterling went in to buisnes around '02. Can you help ?
Albert Allen
11-17-2000 12:16:41
RE: Sterling engine
A true Sterling is strictly a heat engine. What the sparkplugs are doing here puzzles me. It is not an internal combustion engine.
Is Sterling the manufacturer or the engine type?
ubermich
04-05-2001 20:00:46
 Re: Re: Re: Re: Re: Re: Sterling marine engine. in reply to Albert Allen, 11-17-2000 12:16:41
If you are talking about a sterling (type) engine then (theoretically) you could take a prop/shaft and cut it down so that is it supported at the edge of the boat and at another point about 6-9 in. from the end of the shaft. Then attach a rod (you'll have to try diff. legths) too give the shaft a look like __
thisispurelytotakespacesoitwilllineupwhichitdo \_____ __
then attach the engine to the portion you addaed to the shaft OR (depending on your type of engine I've seen a couple of diff. ways to exert power) leave the shaft straight and attach the end of the shaft directly to the engine. You'll have to expirement a little but maybe this'll get the brain fluids movin.
Hope this helps
Ubermich
