Stationary Engines Discussion Forum
torque spec's WI TFD
Wm Smith
07-30-2007 07:57:45
Anyone know where you can get the torque spec's for the Wisconsin Air Cooled models TE-TF?
Thank you for any information
Bill
dobber
08-09-2007 10:23:18
 Re: torque spec's WI TFD in reply to Wm Smith, 07-30-2007 07:57:45
Do a search for Intertec Publishing. They have a manual LES1-4 Large Air Cooled Engines prior to 1988 that covers several Wisconsins and other older large air cooled engines. Chapter for TE,TF,TH,THD,& TJD gives these: cylinder head16-18 ft. lbs., cylinder block 32-34 ft.lbs., connecting rod 22-28 ft.lbs., main bearing plate 24-26 ft.lbs., engine base 22-24 ft.lbs., gear cover 16-18 ft.lbs., manifold mounting nuts 26 ft.lbs. Other Wisconsin manuals and downloads at these: wisconsinmotors.com contintentalengines.com daveparts.com planopower.com
Wm Smith
08-10-2007 18:52:59
 Re: torque spec's WI TFD in reply to dobber, 08-09-2007 10:23:18
Thank you for the information
Bill
