Stationary Engines Discussion Forum
Wisconsin TFD specs
Revredneck
05-25-2007 18:59:32
I'm trying to restore a Wisconsin TFD engine, but I can't find any specs on the engine, such as the dimensions of the crank throws and the clearances and torque specs for the rods. I have the operator manual, but I need more info. please.
Good Luck and God Bless, Tommy
Wm Smith
07-30-2007 07:52:14
 Re: Wisconsin TFD specs in reply to Revredneck, 05-25-2007 18:59:32
piston to cylinder at piston skirt .004 to .0045"
piston ring gap .015"
piston ring side clearance in grooves
top ring .002 to .0035"
2nd ring .001 to .0025"
scraper ring .001 to .0025"
oil ring .0025 to .004"
connecting rod to crank pin
diameter .0007 to .002"
side .004 to .010"
piston pin to connecting rod bushing .0005 to .001"
just run across this site
Bill
Jerrycpp(WA)
06-14-2007 21:57:15
 Crank Size in reply to Revredneck, 05-25-2007 18:59:32
More research: Crank size for rods is 1.75/1.751, Rod bore is 1.8745/1.8750, Oil clearance is .0009/.0030, Maximum wall thickness is .613, Lengh of rod bearing - .864. Undersizes available -.010 and -.020. Part number is 3520SB
Bore 3.000, Stroke 3.250, CID = 45.9
Jerrycpp(WA)
06-14-2007 20:08:29
According to the Federal Mogul Engine Bearings Shop Manual, the TF and TH series had babbited rods with shims. All the shop manual gives is torque - Rods: 24 Ft Lbs, Mains: 30 Ft Lbs, and Head bolts 24 Ft Lbs.
JOB
05-26-2007 20:16:16
I don't have rod diamenter, but rod clearance is .0007 to .002. side clearance is .004 to .010. Connecting rod nuts are 22to 24 foot pounds of torque. then install "pal" lock-nots and tighten with wrench 1/4 turn beyond finger-tight position.
