Stationary Engines Discussion Forum
ve4 wisconsin
troy21
11-22-2006 19:35:34
i have a wisconisin ve4 motor.. im needing to know if any of u all have a start for this u would like to sell. mine is junk and i cant find one.. any help is gratful.. thanks in advance
troy21
11-27-2006 12:44:23
 Re: ve4 wisconsin in reply to troy21, 11-22-2006 19:35:34
ok guys, i hate to keep braing this subject up.. but could some one tell me if this mbg-4109 starter is the same as the mz-4118 one that i have only the mbg-4109 is 12 volt right.. is it the same mounting style and drive stly.. my parts dealer sayes if i order the mbg-4109 and its wrong im stuck with it.. ans thats 200+ dollars down the tube..so coulde some one show me a pick or know for sure that this starter will wrok on my motor.. thanks very much troy
George G
11-30-2006 07:48:03
 Re: ve4 wisconsin in reply to troy21, 11-27-2006 12:44:23
I would say that it would drop right in.
Course, Wisconsin has changed the P/N, it is now YA 54 A.
Go to this web site. Maybe you can find a better parts suppler.
troy21
11-24-2006 16:32:50
George G.. are them starters the same as the one i got on my ve4.. only a 12 volt right..
George G
11-24-2006 18:58:41
 Re: ve4 wisconsin in reply to troy21, 11-24-2006 16:32:50
Thats the numbers Wisconsin gives in their book.And yes, those are the numbers for 12-volt starters.
The numbers for 6-volt starters would be, Wisconsin P/N YA-19-3-S1 and Prestolite P/N MZ-4192, MZ-4184 & MZ-4118
George G
11-24-2006 07:47:59
For a 12-volt starter for a Wisconsin VE4D/VF4d. The Wisconsin P/N would be YA-18-3-S1. The Prestolite P/N would be MBG-4109 and MBG-4024
Kent of SW MO
11-24-2006 03:00:25
Troy21,
In my humble oppion the starter rebuild place you took your old starter to DID NOT want to work on your starter. The field coils can be replaced and if need be the armature can be rewound. It depends on how much money you want to spend.
Kent
troy21
11-23-2006 18:39:25
my old starter is tost.. all the insides are melted is what the starter re-bild guy sayed.. so im needing a new one or good used one.. i need a 12-volt start.. mine was a 6-volt but they had a 12-volt battery on it with out it being cut down to the 6-volt.. so thats why it burnt up.. the number on the starter is auto-light mz 4118.. can someone tell me a match to this starter in a 12-volt instead of a 6-volt??
zira
11-23-2006 14:49:06
Do you need 6 volt or 12 volt?
Kent of SW MO
11-23-2006 08:45:03
I assume you need a starter. Have you tried taking your old starter to a starter rebuild shop. I bet that can fix your old one.
Kent
