Stationary Engines Discussion Forum
JD model E Ser #
DCM
10-13-2006 12:29:02
Looked at a 1 1/2 hp today, serial # shows 3 6451,is that an actual ser.# or should I be looking somewhere else on the engine.Thanks, Dan AB
DCM
10-14-2006 19:49:28
 Thanks ken in texas in reply to DCM, 10-13-2006 12:29:02
I flagged the site.Where is the JD engine Ser # list link.Dan AB
ken in texas
10-14-2006 08:07:02
 Re: JD model E Ser # in reply to DCM, 10-13-2006 12:29:02
I found a serial number list for JD model E on www.oldengine.org . If I am reading it right your engine is a 1943 year model. The engine I have shows to be a 1929 model .If I can help in any way let me know.
ken in texas
10-13-2006 13:41:07
Looks like I spoke too quickly. The early models number is year model but not later models
ken in texas
10-13-2006 13:10:10
That does'not sound like a correct serial number. Where did you find it on engine. It should be found on side plate below the mag and should 6 numbers, the first two indicating the year model.Hope this helps.
DCM
10-13-2006 20:31:41
 Re: JD model E Ser #-update on numbers in reply to ken in texas, 10-13-2006 13:10:10
I had a real close look and this is what I saw,#356451,would it have been made in the mid 1930s?Dan AB
