Stationary Engines Discussion Forum
Wisconsin VE4D Specs
Anderson
07-26-2006 12:59:04
Does anybody know the valve clearance,Head torque seqence and torque, and rpm for a VE4D wisconsin engine.
Seblim
07-27-2006 01:01:38
 Re: Wisconsin VE4D Specs in reply to Anderson, 07-26-2006 12:59:04
I am assuming it is the same as VF and VH4D
Inlet 0.008 thou of an inch
Exhaust 0.016 thou of an inch
Torque 25 Ft Lbs with 5/16 UNC high tensile bolts � grade 5 I think they were. The longer ones go in the hole near the spark plug where the head is slightly thicker. Again if this is same as VF and VH engines
Sequence � can�t remember
