Stationary Engines Discussion Forum
Protection of carb gaskets
Ron (NETexas)
06-13-2006 04:37:20
I purchased a new Pacer pump with a Briggs 3.5 engine. Since I don't plan to place this pump into service for a year or so, do I need to occassionally start the engine to keep the carb gaskets from drying out? This is a new engine and never had gasoline in it.
DNWELDMAN
04-19-2007 01:23:36
 Re: Protection of carb gaskets in reply to Ron (NETexas), 06-13-2006 04:37:20
Hi. Are you sure there has never been gas in it? What about a factory fire up to make sure eng works? If there has never been gas in it, then you can let it sit until you are ready for it, just like it was sitting on the shelf before you bought it. If there was gas in it, then just make sure it is all out of the bowl and you'll be good. Doug
