Stationary Engines Discussion Forum
Wisconson parts
Lloyd Stricklan
04-08-2006 13:01:34
Anyone know where I can get a .060 piston for a VH4D?
doogdoog
04-18-2006 22:15:09
 Re: Wisconson parts in reply to Lloyd Strickland, 04-08-2006 13:01:34
Aloha, I had some good results finding parts for my engines from this link.
Mahalo,
doogdoog
Lloyd S
04-11-2006 16:47:50
Thanks for the reply. I have already run the engine two seasons bored .060 over with no problems. I killed it by spraying dried corn with no screen on the flywheel. Clogged the air ports, ran hot and gaulded one piston. Found another piston today so should be spraying again this season. Thanks
Lloyd S
senlim
04-09-2006 17:15:02
Oversize pistons originally were +0.005, +0.010, +0.020 and +0.030. If you were able to get a +0.060 you would have very thin cylinder walls or maybe even able to see the piston through the fins ;-). Better fix is to get dry sleeves fitted and go back to Std
