Stationary Engines Discussion Forum
Maytag 72 won't run.
Jess Potter
02-04-2006 17:55:31
Hi, I just did a restoration on a 1939 Maytag 72d I have it all painted and back together it has spark, gas, and the timing is right but I can't get the damn thing to even backfire I get absolutely nothing out of it but I'm sure it has spark. I've even poured a little gas in the cylinders down the intake tube, I tried hot plugging it. When I took it apart the rings seemed good. I have never had it running. Well any help would be great. Thanks alot, Jess
slowfolk
03-05-2006 08:13:33
 Re: Maytag 72 won't run. in reply to Jess Potter, 02-04-2006 17:55:31
Check for compression, may need to get some oil around the rings.
Jess Potter
03-05-2006 22:12:03
 Re: Maytag 72 won't run. in reply to slowfolk, 03-05-2006 08:13:33
Thats exactly what it was. I checked Dry compression only registered at 45#. Then I checked wet compression(added marvel to cylinders) and it came in at 70#. So it must be my rings are shot. I am also looking for a crank its a 1939 72-D. If anybodys got one. Thanks Jess
