Stationary Engines Discussion Forum
Petter A1 Ignition timing
Jim Bovingdon
01-24-2006 09:40:43
I am having trouble getting my Petter A1 to start. It always seems to fire out of the carburettor (scary). Should the impulse generator "click" twice during a four stroke cycle?
I thought it might be just as you feel the compression??? not elsewhere in the cycle?
Kent of SW MO
01-26-2006 05:41:26
 Re: Petter A1 Ignition timing in reply to Jim Bovingdon, 01-24-2006 09:40:43
I do not "know" you engine but the impluse should only snap as the crank breaks over top dead center between the end of the compression stroke and the beginning of the power stroke. If the impluse is engaging at another point you may have the wrong mag. You mag may have the body from a four cylinder unit on which the impluses engage every 180 degress of magneto shaft rotation.
Kent
