Stationary Engines Discussion Forum
Serial Number Flywheel Removal
mark k
01-09-2006 19:40:27
Hello, I just aquired a model 31 or at least that's what it says on the tag, I was wondering where the serial number is located and how do you remove the flywheel to get at the points? Thanks Mark
Kent of SW MO
01-10-2006 06:56:51
 Re: Serial Number Flywheel Removal in reply to mark k, 01-09-2006 19:40:27
Model 31 WHAT?
Kent
mark k
01-10-2006 17:55:21
 Serial Number Flywheel Removal in reply to Kent of SW MO, 01-10-2006 06:56:51
Sorry, Maytag 1 cyl. Brain gas I guess. Mark
Someone
01-13-2006 20:17:52
 Re: Serial Number Flywheel Removal in reply to mark k, 01-10-2006 17:55:21
The numbers stamped into the flywheel rim are the serial #.
To remove flywheel, run flywheel nut out until it is even with the end of the crankshaft. Place a board or piece of brass across the nut to soften the blow, and smack it with a hammer.
