Restoration & Repair Tips Board
W6 Gas Gauge
Yugrotcart
03-18-2006 18:33:44
I posted this on the Farmall site, and no one had the answer. I have a fuel gauge with a rotten cork float. Anyone have an idea on how to fix it, cork is awfull hard to find..... ...
Bob
03-18-2006 21:26:53
 Re: W6 Gas Gauge in reply to Yugrotcart, 03-18-2006 18:33:44
Why not use a brass float?
If you email me, I can give you a part # (NOT IH) for a brass float.
If you need a float with a hole in the center, that a wire passes through, check out fuel senders from junked vehicles. As an example, a fuel gauge sender float from a 1990 Chevy pickup is plastic, and has a hole through the center for the wire float arm.
Also, I understand some radiator shops that repair gas tanks have a source for floats.
For gosh sakes, don't use some insulating foam, or other substance that will eventually disolve!
Can you imagine the mess that would make in the fuel system!
[email protected]
Ed Lotterman
03-18-2006 20:04:56
 Re: W6 Gas Gauge - cork in reply to Yugrotcart, 03-18-2006 18:33:44
Cork is hard to find but you can get it. Try a scientific lab supply place. Your local high school science teacher should have copies of catalogs. They still make cork stoppers for lab tubes and flasks and you could whittle a big one into the shape you need.
I also heard of a guy using balsa wood to make a float like that, but he had to put some sort of paint or epoxy on it to keep it from getting waterlogged with gas after a while. I understand that the problem with using most plastic foam like insulation board is that eventually the gasoline dissolves it. But there supposedly is some epoxy, maybe the kind that boatbuilders use, that you can coat it with that resists gas.
Good luck
If you email me I can try to run down a big cork for you.
Yugrotcart
03-19-2006 06:34:10
 Re: W6 Gas Gauge - cork in reply to Ed Lotterman, 03-18-2006 20:04:56
Off to spend quailty time iwth the mother inlaw today and there is a big craft store where she live. I will see if they have a large cork that will work, if not I will be in touch. Thx,Paul
