Spark plug thread repair
Mike
02-28-2002 19:08:16
I have an aluminum head from an air cooled engine with the plug threads pulled out of it. It takes a 7/8" plug. The threads are not 7/8" NF. Does anybody make a helicoil type repair kit for these? What other options do I have besides finding another head? Thanks for any help.
Steve
04-11-2002 10:26:46
 Re: Spark plug thread repair in reply to Mike, 02-28-2002 19:08:16
There is a wonderfull product made for thread repair of almost any size including spark plugs. Its called Time-Sert. It is a permanent thread repair. As a former almn/cyl head shop mgr. we used them to save heads daily! They work great and stay in, unlike heli-coils that can come out. Our distributor was Winzer Inc. If you can't find them let me know.
Wayne Swenson
03-07-2002 20:00:43
Be sure not to try and oversize the hole.
Get an 18mm thread repair kit or see your favorite auto-truck-tractor machinist and have them put in a replacement thread.
Spark plug threads are most likely metric even though the wrench is fractional sized.
Don Young
03-02-2002 21:20:45
I noticed that 3/4" iron pipe thread seems to be a possibility for an oversize thread bushing. It would probably be pretty small to drill and tap to 7/8-18 for the original plug, might use 1" pipe thread if you want the original plug size.
Don Young
02-28-2002 20:56:27
I don't know offhand what the pitch of the 7/8" plugs is but if you can't find a helicoil you could thread the stripped hole to any larger size and have a repair plug machined and threaded to screw into the head. The repair plug could be internally threaded to fit the 7/8" spark plug, 18MM, or whatever you want. Another alternative is to have the hole welded up, then redrilled and tapped. Hope this helps.
