Restoration & Repair Tips Board
cab weatherstripping
joe/pa
03-02-2006 09:22:26
Does anyone know where I could find the weatherstripping/gaskets for a Hinson Cab? I've had no luck with aftermarket or even my Oliver dealer Thanks!
msb
03-02-2006 19:33:44
 Re: cab weatherstripping in reply to joe/pa, 03-02-2006 09:22:26
Try here they carry all sorts of weatherstripping.
www.jcwhitney.com/autoparts/StoreCatalogDisplay/c-10101/s-10101
JMS/MN
03-02-2006 16:28:51
Do a search for 'Fehr Cab Interiors'. They have the foam interior- might have the stuff you need?
joe/pa
03-04-2006 04:34:47
 Re: cab weatherstripping in reply to JMS/MN, 03-02-2006 16:28:51
Thanks for the info. I found a company out in california that carries the Fehr interior parts. They are sending out some door gasket samples, sounds like they are going to work.
JMS/MN
03-04-2006 08:54:12
 Re: cab weatherstripping in reply to joe/pa, 03-04-2006 04:34:47
I believe Fehr is in Illinois- should be able to deal directly with them, unless that policy is changed. Probably less freight for you, if in PA.
Joe/pa
03-04-2006 10:18:46
 Re: cab weatherstripping in reply to JMS/MN, 03-04-2006 08:54:12
I did some more searching and found their number. I'll give them a call next week.
Glen in TX
03-02-2006 14:12:57
Try Mill Supply or even some local truck part shops or glass shops in your area also.
