Restoration & Repair Tips Board
ford backhoe
ibuildcars4u
02-11-2006 11:39:07
need some help please. i have just bought a mid 70's ford 4500 backhoe. on the rear of the tractor where the backhoe attaches to the tractor on the bottom, there is 2 { i dont know what they are called or how to describe them} upside down " c " brackets that hold the 2 bottom pins of the backhoe. 1 c bracket is broken off, when you go to use the backhoe, the pin pops out of the bracket causing the backhoe attachment to fall down. what is the name for these brackets? and do they sell replacement parts? or do i have to fab my own? any help would be appreciated. dont know much about backhoes, but i am learning, thank you for your time and help.
retired farmer
02-26-2006 20:07:06
 Re: ford backhoe in reply to ibuildcars4u, 02-11-2006 11:39:07
I rebuilt one once but don't remember what it is called. If it is a welded on casting you will probably have to make your own and weld it on. If it is part of a frame assembly casting they probably don't make replacement parts for it. Call your ford dealer.
