Restoration & Repair Tips Board
Oil Pressure Guages Gone Wild
JKC
02-09-2006 20:47:03
I am looking for some advise. Bought a 1952 Minneapolis Moline ZAU tractor. The generic oil pressure gauge was bobbing up and down, never advancing over 20 PSI, no matter how much I adjusted the regulator (I think it's a bad gauge). I put an oil pump that I know is working from an identical tractor on it, same thing. I put the oil pressure gauge from the identical tractor on it and it will not go over 20 PSI, no matter how much I adjusted the regulator (I think it's a bad gauge). I then put a newer reproduction gauge from John Deere on it and the pressure went all the way over to the highest side of HIGH! Can't get it to come down below that high reading, no matter how much I adjusted the regulator!! As you can see, I am now absolutely confused as to where to set the regulator! Is there a hugh diffence in the manufacture of gauges? I think the oil pressure is probably fine, but have no way of telling. I have heard that some reproduction gauges are not all they are cracked-up to be. I am looking for suggestions on where to purchase a reliable oil pressure gauge for a 1952 MM tractor. Thank you.
CNKS
02-10-2006 05:51:28
 Re: Oil Pressure Guages Gone Wild in reply to JKC, 02-09-2006 20:47:03
Your first stop should be the MM site, someone wil know where you can get the proper gauge, and can also tell you if there is anything else wrong. This section of YTMag is more for general, not model specific questions.
old
02-09-2006 21:23:00
First off a lot of tractors had low oil preassure, say around 20-30 psi. The JD gauge you put on probably maxed out some place around the 20 psi. Oliver gauges are about the same. To really adjust it right you need a very high dollar gauge that is calibrated. Or you can just live with useing a guage that will only go up to around 30 psi or so, they can be hard to find, I know I have been looking for a couple. Most of them I find now days go up around 100psi which is way to high for most old tractors.
