Rust!!
James B
02-27-2002 11:28:23
What is the best way to get all the rust off the wheels and mud guards. I am restoring a 1963 Super Dexta and want it to look really good.
Any help
Thanks
Brad_bb
03-14-2002 08:40:22
 Re: Rust!! in reply to James B, 02-27-2002 11:28:23
There are a bunch of choices here. There is Acid -muratic(swimming pool acid) acid is found at the local hardware store, buy there are some safety precautions that must be heeded for this method. For light surface rust there is mild phosphoric acids available at the autobody paint stores. I believe Oxysolve is phosphoric acid. Then there is of course sandblasting. You can also phosphoric acid wash after blasting and before priming for extra measure. Finally there is another method I recently tried. Electrolytic alkaline rust removal. To understand the theory, read the article at www.oldengine.org/members/billd/electrol.htm I used an outfit here in Chicago called Redi-Strip who use this process on a very large scale. They can strip whole bodies this way. I recommend this process for any part that you will be able to prime/seal every part of the part. If there are hidden areas that you can't prime, the process will expose those to the air. The Redi-strip process leave some protection from rust for about 30 days(that is how much time I was told you have to seal the parts). There are other Redi-strip locations across the country. Probably do a search on the web and look in Hemmings motor news under services offered or tools and services.
Brian
03-03-2002 18:01:05
Try a product called Oxi-Solv. POR products sell it, as well as independants.
