I screwed up. I have a Farmall M engine block that was sent to the shop for $600 of work (it was not pretty before). When it was returned I installed the crank with new bearings, new pistons with rings in the new sleeves the shop installed.Then we moved and the block was hauled to my new location, placed in the barn under cover and not touched for two months as I helped my wife get the house in order. Now I have light surface rust on the sleeves and the top of the block. I used prelube and coated everything with 90 weight gear oil but obviously that was not the trick to store it. First question, what do I use to get the rust off? If I use Emory cloth, steel wool or other light medium there will be filings, etc. in places that are not the best as the rings and bearings are still in. Or does it have to be re-torn apart? I am also thinking about Picklex as well but not sure how that would react with the gaskets or oil later on? Secondly, how do I keep the rust from returning until I can get the pieces painted and start reassembly? Picklex is obvious but same concerns as above. My only thought is grease as the 90 oil did not work. Thanks for any advice.
