Restoration & Repair Tips Board
REAR CAST WHEELS
KENC
12-28-2005 15:47:25
I WANT TO PAINT MY REAR CAST WHEELS BUT DON'T WANT TO GO THROUGH THE TROUBLE OF ATTEMPTING TO REMOVE THEM INTACT. CAN I REMOVE THE RIMS SEPARATELY AND WHAT'S INVOLVED?
THANKS,
PatCox
12-31-2005 04:06:56
 Re: REAR CAST WHEELS in reply to KENC, 12-28-2005 15:47:25
KENC,
Take a close look at the cast center and wheel. If the clamps are on the inside (normal), the rim should be trapped between the clamps and raised segments on the outside of the wheel. If you jack the tire off of the ground, you should be able to remove the clamps and wiggle the wheel around more or less parallel to the axle. From there, the wheel can be slid off of the cast center to the front or back. The wide spaces between the raised segments on the center will give the clearance you need. Then all you have to worry about is the weight of the tire and rim (hopefully, the tire isn�t loaded with fluid). When I took the rims off of my B, it was �tip it a little, slide it a little, repeat as necessary.�
Pat
kenc
12-31-2005 05:23:41
 Re: REAR CAST WHEELS in reply to PatCox, 12-31-2005 04:06:56
thanks pat,
i will try your approach.
old
12-28-2005 19:06:36
Very hard to help with out knowing what tractor your talking about. Theres probably 1000 plus tractors with cast rim center and all of them are differant.
kenc
12-29-2005 06:15:20
 Re: REAR CAST WHEELS in reply to old, 12-28-2005 19:06:36
sorry old,
i have a 1936 jd model d ser# 129229. hope this helps and let me know please.
thanks
old
12-29-2005 09:02:59
 Re: REAR CAST WHEELS in reply to kenc, 12-29-2005 06:15:20
Thats one I can't help with. If it was a B around 1935 or a 60 around 1955 I might be able to but I have never even seen a D in person.
