Restoration & Repair Tips Board
farmall b final drive noise
Rob Miller
12-02-2005 13:57:16
My farmall B has a VERY noisy final drive. From the drivers seat I would guess its coming from the bull gears on both sides. I have heard a few Farmall A & B's but mine is by far the growliest! All speeds have the same noise. Has the same amount of noise in reverse...maybe the gears were spapped sides? My manual talks about shims in the trans to get the proper "bite" on the ring gear..would this have any effect? I have looked at the bull gears for wear and they look fine. Wheels feel firm against shimmy, I think the bearings are fine. Changed to a 90-180 weight oil in the finals and that helped a little. Hmmm ??
Red Dave
12-05-2005 07:17:22
 Re: farmall b final drive noise in reply to Rob Miller, 12-02-2005 13:57:16
Might be worn-out bearings too. You'll have to take the drive off the tractor and remove the axle from the bull gear to get at the outboard bearing.
I run about a half a can of STP in the gear oil of each of my final drives. It helps quiet the gear noise, but I wouldn't do that if there is any possibility of the noise coming from a bearing.
